An ultrahigh carbon steel alloy containing 1.4 wt pct carbon (UHCS-1.4C) was studied. The steel was processed into ultrafine grain and fully spheroidized microstructure through a controlled rolling and controlled-cooling divorced eutectoid transformation, and was then given austempering treatment to form bainite. The mechanical properties of the heat-treated steel were evaluated by tension tests at room temperature. After austenitized at 850 °C and then austempered at 300 - 350 °C, the microstructure was ultrafine upper bainite, retained austenite, and unsolvable cementite. It was shown that the ultimate tensile strengths of UHCS-1.4C ranged from 1420 to 1830 MPa, elongations to failure from 6 to 14%; the ultimate tensile strength increases with decreasing austempering temperature, while the tensile ductility decreases. The fracture surface of bainitic UHCS-1.4C consists mainly of dimples and voids, which reveal a ductile fracture. The present results indicate that ultrahigh carbon steel can be easily processed to achieve bainitic microstructures and unique properties.
一个超高碳钢合金含有1.4 wt pct碳(uhcs - 1.4 c)进行了研究。钢晶粒超细化加工成,完全球化处理组织通过控制轧制和controlled-cooling离异共析转变,和当时贝氏体等温淬火处理形式。热处理钢的机械性能被张力测试在室温下进行。在850°C,然后austempered austenitized后300 - 350°C,超细上贝氏体组织,残留奥氏体,解决渗碳体。 结果表明,极限抗拉强度的uhcs - 1.4 c范围从1420到1830 MPa,elongations失败从6 - 14%;极限抗拉强度的增加而减少等温淬火温度,而拉伸延性下降。贝氏体的断裂表面uhcs - 1.4 c主要由酒窝和空洞,这显示出韧性断裂。目前的结果表明,超高碳钢可以很容易地处理获得贝氏体显微结构和独特的性质。
超高碳钢与渗碳钢力学性能 材料 | 奥氏体化温度/℃正火 | 屈服点ss/MPa | 抗拉强度sb/MPa | 屈强比(ss/sb) | 延伸率d/% | 面缩率y/% | 断裂强度sf/MPa | UHCS-1.4C | 780 | 624 | 934 | 0.67 | 22 | 36 | 1256 | UHCS-1.4C | 820 | 902 | 1307 | 0.69 | 13 | 31 | 1700 | UHCS-1.4C | 860 | 953 | 1439 | 0.66 | 12 | 26 | 1748 | UHCS-1.3C | 860 | 903 | 1327 | 0.68 | 12 | 31 | 1702 | 20CrMnTi | 880淬火/200回火 | 835 | 1080 | | 10 | 45 | | 20CrMnMo | 850淬火/200回火 | 885 | 1175 | | 10 | 45 | |
