查看: 2776|回复: 4
搞感应热处理的看看这
发表于 2013-3-5 19:20:22 | 显示全部楼层 |阅读模式
Induction hardening is a form of heat treatment in which a metal part is heated by induction heating and then quenched. The quenched metal undergoes a martensitic transformation, increasing the hardness and brittleness of the part. Induction hardening is used to selectively harden areas of a part or assembly without affecting the properties of the part as a whole.[1]
Contents [hide]
[edit] ProcessInduction heating is a non contact heating process which utilises the principle of electromagnetic induction to produce heat inside the surface layer of a work-piece. By placing a conductive material into a strong alternating magnetic field, electrical current can be made to flow in the material thereby creating heat due to the I2R losses in the material. In magnetic materials, further heat is generated below the curie point due to hysteresis losses. The current generated flows predominantly in the surface layer, the depth of this layer being dictated by the frequency of the alternating field, the surface power density, the permeability of the material, the heat time and the diameter of the bar or material thickness. By quenching this heated layer in water, oil or a polymer based quench the surface layer is altered to form a martensitic structure which is harder than the base metal.[2]
[edit] DefinitionA widely used process for the surface hardening of steel. The components are heated by means of an alternating magnetic field to a temperature within or above the transformation range followed by immediate quenching. The core of the component remains unaffected by the treatment and its physical properties are those of the bar from which it was machined, whilst the hardness of the case can be within the range 37/58 HRC. Carbon and alloy steels with an equivalent carbon content in the range 0.40/0.45% are most suitable for this process.[1]
A source of high frequency electricity is used to drive a large alternating current through a coil. The passage of current through this coil generates a very intense and rapidly changing magnetic field in the space within the work coil. The workpiece to be heated is placed within this intense alternating magnetic field where eddy currents are generated within the workpiece and resistance leads to Joule heating of the metal.
This operation is most commonly used in steel alloys. Many mechanical parts, such as shafts, gears, and springs, are subjected to surface treatments, before the delivering, in order to improve wear behavior. The effectiveness of these treatments depends both on surface materials properties modification and on the introduction of residual stress. Among these treatments, induction hardening is one of the most widely employed to improve component durability. It determines in the work-piece a tough core with tensile residual stresses and a hard surface layer with compressive stress, which have proved to be very effective in extending the component fatigue life and wear resistance.[3]
Induction surface hardened low alloyed medium carbon steels are widely used for critical automotive and machine applications which require high wear resistance. Wear resistance behavior of induction hardened parts depends on hardening depth and the magnitude and distribution of residual compressive stress in the surface layer.[2]
[edit] HistoryThe basis of all induction heating systems was discovered in 1831 by Michael Faraday. Faraday proved that by winding two coils of wire around a common magnetic core it was possible to create a momentary electromotive force in the second winding by switching the electric current in the first winding on and off. He further observed that if the current was kept constant, no EMF was induced in the second winding and that this current flowed in opposite directions subject to whether the current was increasing or decreasing in the circuit.[4]
Faraday concluded that an electric current can be produced by a changing magnetic field. As there was no physical connection between the primary and secondary windings, the emf in the secondary coil was said to be induced and so Faraday's law of induction was born. Once discovered, these principles were employed over the next century or so in the design of dynamos (electrical generators and electric motors, which are variants of the same thing) and in forms of electrical transformers. In these applications, any heat generated in either the electrical or magnetic circuits was felt to be undesirable. Engineers went to great lengths and used laminated cores and other methods to minimise the effects.[4]
Early last century the principles were explored as a means to melt steel, and the motor generator was developed to provide the power required for the induction furnace. After general acceptance of the methodology for melting steel, engineers began to explore other possibilities for the utilisation of the process. It was already understood that the depth of current penetration in steel was a function of its magnetic permeability, resistivity and the frequency of the applied field. Engineers at Midvale Steel and The Ohio Crankshaft Company drew on this knowledge to develop the first surface hardening induction heating systems using motor generators.[5]
The need for rapid easily automated systems led to massive advances in the understanding and utilisation of the induction hardening process and by the late 1950s many systems utilising motor generators and thermionic emission triode oscillators were in regular use in a vast array of industries. Modern day induction heating units utilise the latest in semiconductor technology and digital control systems to develop a range of powers from 1 kW to many megawatts.
[edit] Principal methods[edit] Single shot hardeningIn single shot systems the component is held statically or rotated in the coil and the whole area to be treated is heated simultaneously for a pre-set time followed by either a flood quench or a drop quench system. Single shot is often used in cases where no other method will achieve the desired result for example for flat face hardening of hammers, edge hardening complex shaped tools or the production of small gears.[6]
In the case of shaft hardening a further advantage of the single shot methodology is the production time compared with progressive traverse hardening methods. In addition the ability to use coils which can create longitudinal current flow in the component rather than diametric flow can be an advantage with certain complex geometry.
There are disadvantages with the single shot approach. The coil design can be an extremely complex and involved process. Often the use of ferrite or laminated loading materials is required to influence the magnetic field concentrations in given areas thereby to refine the heat pattern produced. Another drawback is that much more power is required due to the increased surface area being heated compared with a traverse approach.[7]
[edit] Traverse hardeningIn traverse hardening systems the work piece is passed through the induction coil progressively and a following quench spray or ring is utilised. Traverse hardening is used extensively in the production of shaft type components such as axle shafts, excavator bucket pins, steering components, power tool shafts and drive shafts. The component is fed through a ring type inductor which normally features a single turn. The width of the turn is dictated by the traverse speed, the available power and frequency of the generator. This creates a moving band of heat which when quenched creates the hardened surface layer. The quench ring can be either integral a following arrangement or a combination of both subject to the requirements of the application. By varying speed and power it is possible to create a shaft which is hardened along its whole length or just in specific areas and also to harden shafts with steps in diameter or splines. It is normal when hardening round shafts to rotate the part during the process to ensure any variations due to concentricity of the coil and the component are removed.
Traverse methods also feature in the production of edge components, such as paper knives, leather knives, lawnmower bottom blades, and hacksaw blades. These types of application normally utilise a hairpin coil or a transverse flux coil which sits over the edge of the component. The component is progressed through the coil and a following spray quench consisting of nozzles or drilled blocks.
Many methods are used to provide the progressive movement through the coil and both vertical and horizontal systems are used. These normally employ a digital encoder and programmable logic controller for the positional control, switching, monitoring, and setting. In all cases the speed of traverse needs to be closely controlled and consistent as variation in speed will have an effect on the depth of hardness and the hardness value achieved.
[edit] Equipment[edit] Power requiredPower supplies for induction hardening vary in power from a few kilowatts to hundreds of kilowatts dependent of the size of the component to be heated and the production method employed i.e. single shot hardening, traverse hardening or submerged hardening.
In order to select the correct power supply it is first necessary to calculate the surface area of the component to be heated. Once this has been established then a variety of methods can be used to calculate the power density required, heat time and generator operating frequency. Traditionally this was done using a series of graphs, complex empirical calculations and experience. Modern techniques typically utilise finite element analysis and Computer-aided manufacturing techniques, however as with all such methods a thorough working knowledge of the induction heating process is still required.
For single shot applications the total area to be heated needs to be calculated. In the case of traverse hardening the circumference of the component is multiplied by the face width of the coil. Care must be exercised when selecting a coil face width that it is practical to construct the coil of the chosen width and that it will live at the power required for the application.
[edit] FrequencyInduction heating systems for hardening are available in a variety of different operating frequencies typically from 1 kHz to 400 kHz. Higher and lower frequencies are available but typically these will be used for specialist applications. The relationship between operating frequency and current penetration depth and therefore hardness depth is inversely proportional. i.e. the lower the frequency the deeper the case.
Examples of frequencies for various case depths and material diameters Case depth [mm]Bar diameter [mm]Frequency [kHz]
0.8 to 1.55 to 25200 to 400
1.5 to 3.010 to 5010 to 100
>503 to 10
3.0 to 10.020 to 503 to 10
50 to 1001 to 3
>1001The above table is purely illustrative, good results can be obtained outside these ranges by balancing power densities, frequency and other practical considerations including cost which may influence the final selection, heat time and coil width. As well as the power density and frequency, the time the material is heated for will influence the depth to which the heat will flow by conduction. The time in the coil can be influenced by the traverse speed and the coil width, however this will also have an effect on the overall power requirement or the equipment throughput.
It can be seen from the above table that the selection of the correct equipment for any application can be extremely complex as more than one combination of power, frequency and speed can be used for a given result. However in practice many selections are immediately obvious based on previous experience and practicality.
签到天数: 49 天
发表于 2013-3-5 19:33:47 | 显示全部楼层
龟山先生能介绍些热处理专业相关的英文网站吗?
 楼主| 发表于 2013-3-5 19:43:15 | 显示全部楼层
不是在介绍吗,你打开链接就是
发表于 2013-5-26 11:38:37 | 显示全部楼层
龟山淬火 发表于 2013-3-5 19:43
不是在介绍吗,你打开链接就是
哈哈哈,内容不错
签到天数: 22 天
发表于 2013-5-31 18:48:31 | 显示全部楼层
看不了,没信心看下去,直接复制在线翻译编辑] processinduction加热是一种非接触加热过程,利用电磁感应原理来产生热量的工件的表面层内。通过将导电材料成为一个强大的交变磁场,电流可以在材料从而产生热由于I2R损耗的材料流动。在磁性材料,进一步产生热量低于居里点由于磁滞损耗。电流产生的表面层主要是流动的,这一层是由交变磁场的频率的深度,表面的功率密度,磁导率的材料,加热时间和钢筋直径或厚度。用水淬油加热层,或基于聚合物淬火的表层改形成马氏体结构是比母材更难。[ 2 ][编辑] definitiona表面硬化钢的广泛使用的过程。组件是加热的交变磁场对温度在以上转换范围后立即淬火。该组件的核心仍然是不受其物理性质的处理那些酒吧从它的加工,而案件的硬度可的范围内37 / 58 HRC。碳钢和合金钢的范围在0.40和0.45%个碳当量是最适合这个过程。[ 1 ]源高频电是用来驱动一个大的交变电流通过线圈。通过这种线圈通过电流产生一个非常激烈和迅速变化的磁场在空间内工作线圈。将工件加热放置在这激烈的交变磁场,涡流在工件和电阻产生的焦耳热导致的金属。此操作是最常用的合金钢。许多机械零件,如轴,齿轮,弹簧,进行表面处理,在传递,以提高耐磨性。这些治疗的有效性取决于材料表面改性及对残余应力的介绍。这些治疗中,感应淬火是一种最广泛采用的提高构件的耐久性。它决定了工件的残余拉应力和压应力的硬质表面层坚韧的核心,这已被证明是在延长部件的疲劳寿命和耐磨性十分有效。[ 3 ]感应加热表面淬火中碳低合金钢被广泛用于关键的汽车和机器的应用需要高耐磨性。感应淬火零件的耐磨性能取决于硬化层深度和表面层的残余压应力的大小和分布。[ 2 ][编辑]所有感应加热系统的历史基础是由法拉第发现迈克尔1831。法拉第证明绕两圈围绕一个共同的磁芯可以产生瞬间的电动势,第二在第一线圈里的电流的开关线。他进一步指出,如果电流保持恒定,没有电动势是第二绕组,电流流在相反的方向上受当前是否被增加或减少电路引起的。[ 4 ]法拉第发现电流可以通过改变磁场产生的。有初级和次级绕组之间没有物理连接,在次级线圈中感应电动势被称为诱导,法拉第电磁感应定律是天生的。一旦发现,这些原则在下一世纪左右的发电机(发电机和电动机的设计,这是同一件事的变体)和电力变压器的形式。在这些应用中,任何产生的热量或电或磁电路被认为是不可取的。工程师们竭尽全力,用叠层铁芯等方法来减少影响。[ 4 ]上个世纪早期的原理进行了研究,作为一种手段来炼钢,和发电机的开发提供了所需的功率感应炉。熔钢的方法一般承兑后,工程师们开始探索的过程中使用其他的可能性。它已经知道电流透入深度在钢的磁导率和电阻率的函数,所施加的电场的频率。在米德维尔钢铁和俄亥俄曲轴公司的工程师将这一知识发展的第一表面淬火感应加热系统中使用的电动发电机。[ 5 ]快速容易自动化系统导致的感应淬火过程的了解和利用大量的进展和需要
参与人数 1金钱 +40 收起 理由
龟山淬火 + 40
哦也
GMT+8, 2025-9-7 16:40 , Processed in 0.134048 second(s), 28 queries .
