查看: 3210|回复: 3
(TJ, BJ, DOJ) CV joints,
发表于 2016-8-1 15:54:37 | 显示全部楼层 |阅读模式
In addition to heat treating the typical short shaft/internal spline(内花键) (TJ, BJ, DOJ) CV joints, we can heat treat 450 mm long shaft type CV joints(等速万向节), as well.
The fastest processing time is 16 sec/unit for short types. High-efficiency coils are used in the shaft part to reduce takt times, and we have experience in simultaneous heating in one position of the grooved parts球笼 and shaft parts.  also has extensive experience in hardening equipment for propeller shaft joints 传动轴and flange-type joints.
登录/注册后可看大图
What are Constant Velocity Joints?
Constant velocity joints (CV joints) are driveshaft parts used to transmit drive from an automobile engine to the wheels.
CV joints facilitate the transmission of rotational force from the engine to the driveshaft and to the wheels with minimum loss, even when there are significant bends along the way.
CV joints are widely used in front wheel drive vehicles, but they are used in rear wheel drive vehicles, as well, for their sound-damping properties.降噪
登录/注册后可看大图
登录/注册后可看大图
发表于 2016-8-5 17:29:26 | 显示全部楼层
先生也做传动轴?
 楼主| 发表于 2016-8-5 20:07:05 | 显示全部楼层
腊月寒沫 发表于 2016-8-5 17:29
先生也做传动轴?
芯轴
 楼主| 发表于 2017-11-1 17:08:58 | 显示全部楼层
先生也做传动轴?
接住谈。
GMT+8, 2025-9-5 08:10 , Processed in 0.142100 second(s), 26 queries .
