查看: 4765|回复: 1
11th Heat Treatment - 2017 Held annually, the exhibition Heat Treatment i
发表于 2017-7-24 14:31:33 | 显示全部楼层 |阅读模式
11th Heat Treatment - 2017Held annually, the exhibition Heat Treatment is the only exhibition of thermal equipment and technologies in Russia
Exhibition date: September 18 - 20, 2017
Venue: Hall 1, Pavilion 7, Expocentre Fairgrounds, Moscow, Russia
The organizer: Exhibition Company "Mir-Expo"
Supported by:
登录/注册后可看大图
Heating electric furnaces (chamber, shaft, insulated, with roll-out hearth, etc.)
登录/注册后可看大图
Thermal and chemical-thermal equipment for carbonitrile, carburizing, boriding, hardening, brazing, sintering, MIM, tempering, annealing, magnetic annealing, ageing, relieve internal stresses, etc.
登录/注册后可看大图
Physico-thermal equipment
登录/注册后可看大图
Induction equipment. Frequency converters and transformers for induction heating
登录/注册后可看大图
Vacuum equipment and components of vacuum systems: vacuum furnaces, ovens and sputtering systems; vacuum pumps, vacuum gauges, vacuum valves and valve, gas flow regulators
登录/注册后可看大图
Laboratory muffle furnaces and drying cabinets; Laboratory equipment: spectrometers, devices for contactless temperature measurement, analyzers for determining gas-forming impurities in solid materials
登录/注册后可看大图
Installation of coating, including plasma spraying of protective coatings
登录/注册后可看大图
Equipment for electron beam welding and arc welding in argon
登录/注册后可看大图
Laser-manufacturing equipment
登录/注册后可看大图
Systems low temperature (cryogenic treatment)
登录/注册后可看大图
Industrial washing machines and lines
登录/注册后可看大图
Nitrogen plants, oxygen plant, hydrogen plant, compressor equipment, refrigeration units; - Robotic systems for welding, cutting, bending, milling, handling, application of various coatings; - Cooling systems: cooling towers and chillers
登录/注册后可看大图
Equipment for research of properties of materials, nondestructive testing: hardness testing equipment, equipment for specimen preparation, equipment for mechanical testing, spectrometers, pyrometers
登录/注册后可看大图
Technology for the measurement of temperature, humidity and vacuum: thermocouples, measuring transducers, resistance transducers, safety valves, liner, digital display instruments, measuring stations, simulators, calibrators, parts and components
登录/注册后可看大图
Gas and oil burners, gas supply systems and automation. Pulse burner management system. Control cabinets furnaces
登录/注册后可看大图
Flexible metal hoses of high pressure
登录/注册后可看大图
Centrifugal castings in corrosion, heat-resistant and special steels and alloys
登录/注册后可看大图
The mechanisms for transportation of heated metal, recuperators, muffles, articles of heat-resistant materials
登录/注册后可看大图
Steel castings, heat resistant. Furnace equipment and technological equipment for heat treatment: heat exchangers, trays, grids, baskets, supports, fittings, impellers, radiant tubes, retort, casters, etc. for all types of furnaces
登录/注册后可看大图
Refractories, Insulation and lining of thermal units
登录/注册后可看大图
Laminated fabrics and space-reinforcing woven fabric. Multi-layered woven materials of silica, quartz, alkali free glasssynthetic and carbon fibers and combinations thereof.
登录/注册后可看大图
Special coatings and adhesives for high-temperature industrial processes
登录/注册后可看大图
Lubricants and technical liquids. Technology cleaning and temperature control of industrial fluids. Cooling system
登录/注册后可看大图
Articles of graphite, carbon felt and carbon-carbon composites for high temperature equipment
登录/注册后可看大图
Modification of products and their seal carbon pitch-based and phenolic resins, slip protective coating, laminating surfaces
登录/注册后可看大图
Design and manufacture of thermal units (heaters, current leads, power structures)
登录/注册后可看大图
Modernization of high-temperature furnaces by the use of modern carbon materials: the increase in working space of furnaces. The alignment of the thermal field
登录/注册后可看大图
Commissioning, professional installation, service, repair and overhaul of furnaces and heating eq
发表于 2017-7-25 10:10:31 | 显示全部楼层
9月份的莫斯科不知道咋样,应该很美吧,{:soso__3110130392203091378_3:}
GMT+8, 2025-10-20 23:38 , Processed in 0.096822 second(s), 26 queries .
