查看: 4742|回复: 0
Technology based on enthusiasm Home
发表于 2017-7-28 15:23:10 | 显示全部楼层 |阅读模式
AICHELIN – Equipment and customized solutions for Heat TreatmentOur Products
登录/注册后可看大图
For many heat treatment professionals, the ability to handle added flexibility with varying work pieces and part geometry is critical to the daily work schedule. Aichelin’s Vertical Retort furnace line represents the beneficial out growth of years of practical experience and design within this highly demanding field of application.Read more…
登录/注册后可看大图
Nitrocarburizing has acquired increasing significance especially when the process is combined with steam oxidation. The result of this heat treatment is a wear resistant oxidation layer which is similar to hard chrome plating with comparably good corrosion resistance. Read more…
登录/注册后可看大图
Quality treated parts require impeccably clean surfaces before and after heat treatment. In a majority of cleaning operations, the technician typically arbitrates between the three (3) primary operating variables of time, temperature and concentration in qualifying the Read more…
登录/注册后可看大图
Like a dependable tool, Aichelin´s Chamber furnace line continues to earn its reputation as a reliable and flexible workhorse. These proven attributes are derived from its distinctive and robust design characteristics. Whether implemented as a stand-alone unit or Read more…
登录/注册后可看大图
Heat treatment plants for the heating and subsequent press-hardening of blanks for the automotive industry as well as the hardening of shafts and other steel components. Read more…
Pusher Furnace
Rotary Furnace
Cast Link Belt furnace
Ring Hearth Furnace
Drum Rotary Retort Furnace
Mesh Belt Furnace
登录/注册后可看大图
Flawlessly clean surfaces are essential for the quality of the end products when components are heat-treated. AICHELIN offers systems with aqueous solutions and neutral detergents for cleaning and drying components before and after the heat treatment. Read more…
登录/注册后可看大图
Within many steel heat treatment processes the use of protective atmospheres is essential to maintaining desired surface metallurgical properties. Atmosphere«s provide protection from the negative effects of surface oxidation and decarburization while at the same time Read more…
GMT+8, 2025-10-20 23:38 , Processed in 0.111107 second(s), 26 queries .
